Torque specs?
Torque specs?
So here's the run down.
I have a JDM 4.11 that i wanna rebuild, I got it from Duane. Anyways the front diff had a bad bearing. I pulled the 4.11 Gear off the front diff and put it on a turbo legacy diff because it seems there should be no problems. However, i need torque specs for the bolts on the gear.
This is the diff i removed the gear from, you can see all the bolt holes. Those are the torque specs i need.
Re: Torque specs?
42-49 ft-lbs
You can find the info on page 33 of the libertry drivetrain manual section.
http://www.main.experiencetherave.com/s ... tion_3.zip
Re: Torque specs?
Thanks a lot Josh!
Re: Torque specs?
You're welcome.
