I'd like to go through all the possible seals that will be exposed or accessible during the course of this operation, and replace them as I do this.
I've started a bit of a list for all the parts I will need and could use a hand with it. I'll construct it here below so we can review and discuss... I'd like to end up with a timing belt thread here that specifies a complete parts list with sources for anyone with a Legacy to perform a complete timing belt operation and know that they are also replacing all possible seals and wear components along the way. I also plan to use this thread as a guide for my future timing belt changes, as I have 3 Legacy vehicles that will need them at one point or another soon here.
Here's the list (copied from Google Docs but my links did not make it over... I'll figure that out later) - anyone have corrections / additions / suggestions?:
- *Timing Belt Kit:
GATES Part # TCKWP172 PowerGrip Premium OE Timing Belt Component Kit W/Water Pump; 6 Components (1 Belt, 1 Tensioner, 3 Idlers, 1 Water Pump)- $185.49 with est. tax & shipping from rockauto.com, search for p/n
95172 Belt
160-2060 Water Pump (Will this work OK or would it be worthwhile to get the water pump and gasket from Subaru?)
85461 Camshaft Belt Tensioner
85462 Camshaft Belt Idler x2
85463 Camshaft Belt Idler (Gear)
*Timing belt tensioner self-adjusting hydraulic arm, on oil pump casing (is this a wear item or can I reuse the old one again?)
*Front crank seal
PartsTrain Beck Arnley seal - p/n 052-3640 - $4.97
*Front cam seals
RockAuto Timken - Part # 223230 - Shaft Size: 1.26"; Housing Bore: 1.772"; Seal Width: 0.276"; Seal Outside Dia: 1.781"; Seal Lip Material: Nitrile; Housing Material: Steel; Max Temp: 225°F; Min Temp: -40°F; Seal Type: 320; Press Fit - $3.34 x2
*Oil Pump:
A-1 CARDONE Part # 571390 $43.57 with est. tax & shipping
*Oil Pump to Engine Block O-ring - included with oil pump? Order pump first and confirm.
TIMKEN Part # 710238 $15.54 with est. tax & shipping
*Water Pump - Recommend Subaru OEM!
*Water Pump Gasket - Recommend Subaru OEM!
*Thermostat - OEM 170 degrees F failsafe - Recommend Subaru OEM!
Source locally - AutoZone - p/n 7294-170 - $14.99 local
*Thermostat Gasket - Recommend Subaru OEM!
Source locally - AutoZone - p/n 35524 - $4.99 local
*Permatex Ultra Grey Silicone to reseal oil pump
Google Shopping sources - $18
*Blue Loctite for oil pump back plate screws (to prevent known issue of backing out over time) - Threadlocker Oil Resistant Blue Loctite
Google Shopping sources - 50ml Blue - $20
*Back cover banjo bolt & copper washers in case needs replacement? Is this something I should have a replacement part handy for? If so, anyone know what the part # is or how to find it?
*Rear cam seal:
1 qty. 806946030
RockAuto - SKF - $2.82
*Coolant and oil feed line O-rings:
2 qty. 806915110 - used to seal the coolant & oil feed lines between the block & plate - ("if you have a turbo, there are two other o-rings you should probably replace, and when removing that back cover you will have to remove the banjo bolt which has two copper washers...they can probably be reused, but something to know about")
WorldImpex - $2.44 x2 (is this correct? I am not certain which O-rings these are)
*Wrist pin plugs, if leaking (where do I get these and how tough to replace?)
*Alternator & A/C belts
*Radiator hoses
