Miss-firing
logan9691
Miss-firing
Post by logan9691 »
Car has started miss firing under high boost (15+). I'm wondering if putting an MSD coil in would help fix the problem. Running a 20g Rob tuned ecu, with ignition converter.
thanks.
Logan
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
Re: Miss-firing
Check out this thread
http://bbs.legacycentral.org/viewtopic.php?f=2&t=48133
What's your plug gap.
