Testing Waters WTB: Legacy Wagon Driver Side Rear Suspension
cal_look_zero
Post by cal_look_zero »
I have a TON of positive camber, and a tire in the "spare" compartment that has both shoulders worn to the cords. I may or may not be looking for the suspension components for the driver's side rear. I just got a good strut from the PnP, but I doubt that much camber is a single component being bent. I imagine I'll be needing the front and rear stabilizing links, trailing link, and maybe even the knuckle.
If anyone has a parts car and has these parts in good shape, send me a PM and let me know how much it would cost (including shipping) and I'll get back to you with what I need; all or part.
2006 Honda CBR600RR 39k miles
2003 Mitusbishi Montero Sport LS AWD 121k miles
1992 Subaru Loyale Wagon EA82 4WD 5 Speed 333k miles
1991 Subaru Legacy L Wagon EJ22 AWD 5 Speed 240k miles
1979 Suzuki GS850GN 48k miles
1973 Ford F100 302ci 2WD 69k miles
Omega79
Re: Testing Waters WTB: Legacy Wagon Driver Side Rear Suspen
Post by Omega79 »
Wagon and sedan suspension would be the same, what will be important is whether or not you have a sway bar.
I have some stuff, let me know which you have and what you need...
lucas wrote:There were multiple Legacys with 300k+ miles. Jesus will return on a Turbo Lego.
cal_look_zero
I think I'm good actually. The rear strut was all bent to hell, and I was able to find a good pair of struts from a 93. Thanks though.
Omega79
Post by Omega79 »
No problem man, good to hear it was an easy fix!
