Gang will this transmission work?
criticalm@ss
Post by criticalm@ss »
Found this on craiglist wanted to maybe get it if it fits.
is this the turbo edition?
im a noob.
http://losangeles.craigslist.org/lgb/pt ... 56737.html
92 Leggy Wagon L~2003 Baja~2006 Sti
Falken-18c
Re: Gang will this transmission work?
Post by Falken-18c »
it should work
The only issue that I see is that the final drive ratio will probably not be the same. So you'll need to determine what the final drive ratio is and use the matching rear diff. This trans is likely either a 4.111 or 4.444 FD ratio. Your 92 non-turbo should have a 3.9 FD ratio.
criticalm@ss
thanks bro, i will probably just replace the solenoid and clutch plates on my stock one.
