Gang will this transmission work?
Posted: Sat Nov 12, 2011 6:07 am
by criticalm@ss
Found this on craiglist wanted to maybe get it if it fits.
is this the turbo edition?
im a noob.
http://losangeles.craigslist.org/lgb/pt ... 56737.html
Re: Gang will this transmission work?
Posted: Sat Nov 12, 2011 6:10 pm
by Falken-18c
it should work
Posted: Sun Nov 13, 2011 7:07 pm
The only issue that I see is that the final drive ratio will probably not be the same. So you'll need to determine what the final drive ratio is and use the matching rear diff. This trans is likely either a 4.111 or 4.444 FD ratio. Your 92 non-turbo should have a 3.9 FD ratio.
Posted: Mon Nov 14, 2011 5:13 pm
by criticalm@ss
thanks bro, i will probably just replace the solenoid and clutch plates on my stock one.
