aftermarket wrx header, will it fit on 90-94 legacy turbo
sliverumble
Post by sliverumble »
I was just curious if an aftermarket header/uppipe made for an 02-06 wrx fit on a 92 legacy SS. Also are there flow benefits from this or is it a pointless mod?
Please advise,
Grant
92 SS
-TD04
-3" dp/ turbo back w/HKS can
-wrx/legacy susp combo
-Tribeca Front Sway
-whiteline rear sway
-wrx front brakes
-sti lip
-ver.4 sti tranny w/rear diff
-wrx tmic
-mbc @14.5-15psi w/HKS FCD
-Apexi turbo timer
PhyrraM
Re: aftermarket wrx header, will it fit on 90-94 legacy turb
Post by PhyrraM »
Yes it will fit, but you need to plug the WRX O2 sensor hole.
A small gain on a stock motor, but really only worthy if the turbo-back is already done.
sliverumble
I have a 3" downpipe and exha.use to hks can. Currently running about 15psi
92 SS
-TD04
-Tribeca Front Sway
-wrx front brakes
-sti lip
-wrx tmic
-Apexi turbo timer
Just a note, people have noticed a decrease in turbo spool and torque when going to the larger aftermarket headers.
x2hawt4ux
Post by x2hawt4ux »
why would that happen?
92 turbo legacy: RWD W58 SWAP, td04, 3"tbe, mbc, fmic, wrx brakes/hubs, wrx seats, welded 4.11, fcd, drift steering wheel, Drifting Stickers
Deride
Post by Deride »
Go blow air through a straw then try the same thing with a garden hose. Tell me how fast the air is moving on both.
2002 Impreza 2.0RS 6MT
1992 Jeep Cherokee
1994 SS 5MT RIP
1991 SS 5MT *SOLD*
sliverumble
Good to know, makes sense
92 SS
-TD04
-Tribeca Front Sway
-wrx front brakes
-sti lip
-wrx tmic
-Apexi turbo timer
s1d3way
Post by s1d3way »
is anything extra needed to put the wrx header on? like an up pipe or anything else?
It "should" bolt right up.
