Lifting a 92-94 wagon. What struts?
Dave_J
Post by Dave_J »
I have read so many strut posts and almost all are about dropping it into the weeds. I want to raise mine up some. So what struts give the best lift? I plan on putting 225/65 15 or 225/55 16 on and will need tire to strut clearance too.
I read that the 90-91 struts raise it up 3/4 inch. What are the other struts that lift them up?
And I can not afford a Coil over setup.
Retired US ARMY SIGNAL CORP
65 B-Cuda Formula S, 78 Dodge Little Red Express Truck, 08 Suzuki Burgman 650 Super Scooter, 94 Legacy Touring wagon.
Re: Lifting a 92-94 wagon. What struts?
I believe struts from any 02-04 Impreza bolt up pretty easily and raise the car up. You need springs that fit and you have to do something about the rear strut tops and the rear camber.
I had 03 struts and springs on my 93 turbo sedan and they raised it noticeably. I put 04 WRX sedan struts and 03 WRX wagon springs on my 99 Impreza and they raised it a bunch too.
If you really want it up high, it seems like Forester struts are the way to go, but then you have to be prepared for a really floaty ride. Check out this thread on RS25.com.
zeke
Post by zeke »
i lifted my 90 legacy wagon with forester suspension and my ride isnt "floaty" not even a little bit
91 ss Ej22t dohc td04 sti Slanty haltech elite 1500
