Nothing in the dash works?
cul8tr
Post by cul8tr »
I replaced the heater core. I have checked and rechecked all the plugs. Everything is plugged in that can be. I do not have hazard,tach,cig lighter,turnsignals,radio,rear def. I have power at the fuse block but not at the switches. I have pulled the dash out 4 times because everybody that I have talked to locally says that I have missed a plug. I haven't. Could the Illumination relay have an effect on this? I've racked my brain for 2 days over this.
ErikStrieter
Re: Nothing in the dash works?
Post by ErikStrieter »
I have run into the same exact problem. Have you figured out the issue yet? If so please advise me as to what you found.
It's got to be something not plugged in. That or one of the wires has a break in it.
What year and model do you have?
Post by SILINC3R »
check the fuze box by your left foot. i did the same thing and forgot to plug in the very bottom plug that plugs into the fuze box. solved all my problems. good luck
