I've been through the swap process once already with my '91 L. I'm thinking of selling it to build my '93 TW. I've got my eye on a '94 JDM STi swap. Would it basically be as simple as tossing my '93 22T engine harness on the '94 STi and firing it up? I know what needs to happen for the AT to MT.
This is what I'm looking at...
http://www.ebay.com/itm/350509114957?ss ... 1438.l2649
Swap question
fngearhead
Swap question
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
Re: Swap question
Most likely, no it will not be that simple. You would want to likely run the EJ20 ECU. If you do that you would have to address the coil on plug difference and add wiring and ignitor for the four channel setup. There may also be some other wiring differences, but it's workable. Not sure if that answers your question. Yes it can be swapped into your TW, but it's not really plug & play.
fngearhead
Re: Swap question
In the photos on the ebay link, the engine appears to be running wasted spark ignition with a diamond coilpack ontop of the intake. My '89 EJ20G was COP and I swapped my '91 NA harness and it runs fine on the 22T ecu wasted spark.
Re: Swap question
I did not see that....good eye.
Well in that case, all you would likely need to do is verify the wiring. I would still recommend running the EJ20 ECU since it is matched up to the injectors. Running the ej22t ECU would work ok, but assuming the EJ20 has 440 cc/min injectors, the engine will run rich with the stock ej22t ECU.
fngearhead
Re: Swap question
I don't see that this one comes with an ECU or any wiring. I still have my '89 20G ECU, but have no idea if that would treat this thing right. I've been studying your AT to MT write up. Any differences that you may be aware of between '90 NA and '93 TW wiring? I'm no wire master, but it seems straightforward enough. This wagon will have a manual regardless of which engine ends up in there.
Re: Swap question
There may be some differences in the wiring, maybe wire colors, but the overall components/wiring that need to be modified should be the same. The big difference as we found out is the cruise.
http://bbs.legacycentral.org/viewtopic.php?f=19&t=48235
You can d/l the 92 FSM which has wiring diagrams that will be close if not dead on for your 93.
http://bbs.legacycentral.org/viewtopic.php?f=12&t=14485
keithmoilanen
Re: Swap question
I am about to do a ej257 swap on my 91 spt was wondering if any one has some good advice.
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
1991 Legacy Turbo
Sold 1987 Wagon
Re: Swap question
I'd suggest starting a new thread and try and provide us with some more details on your plan, wiring, engine management, etc.
That will help in being able to provide you with some better feedback.
keithmoilanen
