1990 crank angle sensor
1evlwrx
Post by 1evlwrx »
does anyone have one of these they woul sale? i'm located in AZ, also wondering if anyone has tried to put the outback one on the legacy, just because it is 7-8 times cheaper than the legacy for some reason.
Any and all help is highly appreciated.
Re: 1990 crank angle sensor
I'd suggest posting in the parts shed for a sensor. As for whether the outback sensor would work, that I'm not sure. You'd have to verify the electrical connector is the same, even then there may be some internal differences.
