ej22t flywheel
Joshsmiley55
ej22t flywheel
Post by Joshsmiley55 »
does anyone know if a 2002 wrx flywheel could fit on a 94 ej22t? and if not the 2.0 flywheel will the 2.5?
Re: ej22t flywheel
Yes the 02 WRX flywheel will fit on your motor. The mating surface of the clutch is slightly larger, so I would recommend using a WRX clutch & pressure plate. If you don't, I think the turbo legacy clutch & pp would still bolt up.
Joshsmiley55
Re: ej22t flywheel
awsum thank you
