which pistons?
bmxkelowna
which pistons?
Post by bmxkelowna »
looking to buy some pistons over the winter to bump the CR back up on my 22t block with 25d heads
hoping for some where between 8 and 8.5. what pistons should i be looking at?
NICO
Re: which pistons?
Post by NICO »
wiseco no ?
bmxkelowna
Re: which pistons?
Legacy Turbo 1991-1994 EJ22
K601M975 = 0.020 over, 97.5 bore, 8.5 cr
so stock CR is 8.0:1 and with the dohc heads it goes down to 7.5:1 right?
so with the wiseco it will go from 8.5:1 down to 8.0:1 with the dohc heads?
bmxkelowna
Re: which pistons?
bump?
Re: which pistons?
Well if the over the shelf Wiseco pistons don't work, I think they can make you custom ones. I would suggest contacting Wiseco directly. I'm sure they would be able to help you confirm the numbers.
