CA~FS: 2006 STI oem Strut/springs assy. only 5K !!!
criticalm@ss
Post by criticalm@ss »
I pulled these out around 5k when I put some coilovers in, been sitting ever since.
Perfect condition,
cash offers welcome.
pics coming.
4xsti inverted strut assembly
bidding starts at $400
Took these out around 5ooo miles, had them since.
92 Leggy Wagon L~2003 Baja~2006 Sti
sqc151
Re: CA~FS: 2006 STI oem Strut/springs assy. only 5K !!!
Post by sqc151 »
funny, i just posted in my other thread im looking for 04 STi struts... then u post this...lol. wonder since these are 06 if they will bolt right on my 93ss??... if they do, im interested.
Grayguy
Post by Grayguy »
As far as I know, only the 04' STI is a direct replacement, because they switched the hub setup in 05' to a 5x114.5mm bolt pattern.
92' SS: SOLD
criticalm@ss
yep 05 it changed, these are for 5x114
jefferson
Post by jefferson »
I won't swear to it, but I am pretty sure I saw somewhere that you can use the 05 and up struts, but some mods need to be done to the holes. I don't know where I saw it, but I thought it was here.
Jeff
sqc151
Post by sqc151 »
thanks, ill stick to the 04 for now.
James614
Post by James614 »
According to NABISCO, we can use them. Rears will fit, and fronts need small mods.
http://forums.nasioc.com/forums/showthr ... ?t=1170952
tom@kartboy wrote: you just need to slot the lower bolt hole up 0.330 and machine a spacer to makeup the width difference in the knuckle. took me about an hour total.
Tom
Sounds right to me, I've heard of people doing it. But i wouldn't expect to make them fit in an hour, or that there aren't any special caveats for pre-02 cars.
I tookl the time to search cause I considered these seriously, but I'm in the process of a TD04/AWIC build and I need to stay focused!
