turbo newbie needs help with blow off valve
Snow-Attack
Post by Snow-Attack »
Just bought 1992 touring wagon. has a td04 turbo, wrx top mount intercooler. the previous owner install a vent to atmosphere blow off valve which I believe is messing everything up. car is really doggy and has a code 22 and 23 and check engine light is always going on and off.. kinda smells like gas on occasion too.
got any ideas?
and what do i need to put it back to venting into the the manifold? detailed parts description would be great.
also the speedo cable is broke but i dont think that would affect anything?
thanks
Ben
1994 subaru legacy
MI winter package heated seats,mirrors,dark grey interior,5MT 202k,wrx 16" wheels
1992 Touring Wagon LE
td04 turbo,wrx tmic,tinted windows,sti pink struts,lowering springs,16" wheels,wrx brakes,remote start,keyless entry,alarm
Snow-Attack
Re: turbo newbie needs help with blow off valve
oh and it dies on occasion if you brake really hard... I think that comes back to the manifold pressure issue though?
1994 subaru legacy
Mister Anderson
Post by Mister Anderson »
I have the same set up on my SS and have no problems with the BOV venting to the atmosphere. http://legacycentral.org/library/literature/codes.htm
22 is the knock sensor
23 is the MAF
Oh BTW I have a 02-05 WRX IC. It is impossible to vent the BOV to the manifold. IF it's a 06-07 you should be able to do it.
dscoobydoo
Post by dscoobydoo »
pics would help diagnose
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Snow-Attack
replaced the speedo cable. check engine light is gone seems to be running better to....
thanks for the info guys
1994 subaru legacy
The lack of speed signal can cause havoc with the ECU. I would recommend going back to a recirculating BPV setup over the atmospheric vent valve. Overall, the engine will run better with it.
