My barely over a year old cometic gaskets just failed...
Just like the title says, they failed.... WOW.
Sorry to bitch, but i'm fucking pissed.....
Re: My barely over a year old cometic gaskets just failed...
I've heard plenty of stories about cometic gaskets sucking. I won't ever buy any. Stock ftw.
sqc151
Post by sqc151 »
wow that sucks man.
same here too... stock ftw.
Grayguy
Post by Grayguy »
Yup, and I even ran 22e gaskets in my Tleg and they are fine after 4 years haha
92' SS: SOLD
When you installed them, was the engine deck & heads resurfaced? Were you using stock head bolts or ARP studs?
I've heard mixed opinions on the Cometic gaskets. Unless you have an absolutely flat surface, they're not as foregiving as the stock head gasket. Also, Dan had mentioned using some copper spray gasket material on the top & bottom of the gasket.
How did the gasket fail? Was it catastrophically (blown chunk) or do you have an exhaust leak into the cooling system?
I'm assuming exhaust into the coolant. Ill pull the heads tonight. I got the engine out and mostly torn down. I've had a real rough couple days
Plus I needed a 23 or 24 wrench for the cams. Didn't break the gears loose before I pulled the belt.
No I did not resurface :-(
Yeah....after my similar experience....not resurfacing the heads & deck is a risky proposition on these motors as you push them for more power.
Let us know what you find out.
Well I broke my wrench holding the Cam while trying to loosen the Cam pulley bolt. So they're still not off...
I did see this tho,
What did you see? Maybe I'm missing it in the pics?
I see a hose with a clamp in the middle of it serving no purpose other than a slight restriction in the system.
That clamp was your kink stopper. Look at the discoloration on the left side of the gasket.
Looks the same on both sides to me.
Maybe the pic doesn't do justice. Ill edit it later
Bheinen74
Post by Bheinen74 »
use stock hg x 10000000
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
I'm almost sure I wont even be able to use this engine
Bheinen74 wrote:use stock hg x 10000000
Thats too many. A subaru engine only needs two.
Haha
What really sucks is i just picked up this bad boy
I built a rig for the cam pulleys out of a piece of angle iron and some stainless U-bolts. The bolts went through the spokes of the cams and into the angle iron, which went across the engine to tie the two cams together. Then I just cracked both bolts loose before removing the rig. If you lived close, I'd just give it to you, but it's and easy enough thing to make. I think I may have had to grind some parts of the angle iron to clear various things, but nothing major.
I'm following what you're saying!
euroshark
Post by euroshark »
most knowledgeable subaru performance shops use oem head gaskets and will punch you in the face if you mention cometic.
btw, i see the discoloration in your pic. looks like a stain from burnt coolant=leaking head gasket.
http://r-hgarage.com/ -CLICK ME
92 legacy ss 5spd white- track car
03 wrx wagon 5spd silver- DD
84 chevy k20 4spd 4x4 blue lifted on 35"- wheeler/heavy hauler
there's spots on the top of the rh side blockhalf that are pitted from being too hot. the leaking power steering that was under my intake manifold was boiling.
euroshark
Post by euroshark »
damn, thats terrible
yeah, and with the rarity of the block, i may have to break down and buy an ej20....
wurkenman
Post by wurkenman »
I learned my lesson years ago with Cometic gaskets and Harley's. I will never use their stuff. The best head gaskets are OEM.
