Page 1 of 2
My barely over a year old cometic gaskets just failed...
Posted: Mon Jan 02, 2012 8:36 am
by cj91legss
Just like the title says, they failed.... WOW.
Sorry to bitch, but i'm fucking pissed.....
Re: My barely over a year old cometic gaskets just failed...
Posted: Mon Jan 02, 2012 10:22 am
by kimokalihi
I've heard plenty of stories about cometic gaskets sucking. I won't ever buy any. Stock ftw.
Posted: Mon Jan 02, 2012 2:02 pm
by sqc151
wow that sucks man.
same here too... stock ftw.
Posted: Tue Jan 03, 2012 12:18 am
by Grayguy
Yup, and I even ran 22e gaskets in my Tleg and they are fine after 4 years haha
Posted: Tue Jan 03, 2012 8:34 pm
When you installed them, was the engine deck & heads resurfaced? Were you using stock head bolts or ARP studs?
I've heard mixed opinions on the Cometic gaskets. Unless you have an absolutely flat surface, they're not as foregiving as the stock head gasket. Also, Dan had mentioned using some copper spray gasket material on the top & bottom of the gasket.
How did the gasket fail? Was it catastrophically (blown chunk) or do you have an exhaust leak into the cooling system?
Posted: Tue Jan 03, 2012 9:26 pm
by cj91legss
I'm assuming exhaust into the coolant. Ill pull the heads tonight. I got the engine out and mostly torn down. I've had a real rough couple days
Plus I needed a 23 or 24 wrench for the cams. Didn't break the gears loose before I pulled the belt.
No I did not resurface
Posted: Tue Jan 03, 2012 10:47 pm
Yeah....after my similar experience....not resurfacing the heads & deck is a risky proposition on these motors as you push them for more power.
Let us know what you find out.
Posted: Thu Jan 05, 2012 5:11 am
by cj91legss
Well I broke my wrench holding the Cam while trying to loosen the Cam pulley bolt. So they're still not off...
I did see this tho,
Posted: Thu Jan 05, 2012 6:54 pm
What did you see? Maybe I'm missing it in the pics?
Posted: Thu Jan 05, 2012 11:17 pm
by kimokalihi
I see a hose with a clamp in the middle of it serving no purpose other than a slight restriction in the system.
Posted: Thu Jan 05, 2012 11:28 pm
by cj91legss
That clamp was your kink stopper. Look at the discoloration on the left side of the gasket.
Posted: Fri Jan 06, 2012 12:10 am
by kimokalihi
Looks the same on both sides to me.
Posted: Fri Jan 06, 2012 12:26 am
by cj91legss
Maybe the pic doesn't do justice. Ill edit it later
Posted: Fri Jan 06, 2012 1:02 am
by Bheinen74
use stock hg x 10000000
Posted: Fri Jan 06, 2012 1:14 am
by cj91legss
I'm almost sure I wont even be able to use this engine
Posted: Fri Jan 06, 2012 1:58 am
by beatersubi
Bheinen74 wrote:use stock hg x 10000000
Thats too many. A subaru engine only needs two.
Posted: Fri Jan 06, 2012 2:16 am
by cj91legss
Haha
Posted: Fri Jan 06, 2012 3:59 am
by cj91legss
What really sucks is i just picked up this bad boy
Posted: Fri Jan 06, 2012 11:03 pm
by evolutionmovement
I built a rig for the cam pulleys out of a piece of angle iron and some stainless U-bolts. The bolts went through the spokes of the cams and into the angle iron, which went across the engine to tie the two cams together. Then I just cracked both bolts loose before removing the rig. If you lived close, I'd just give it to you, but it's and easy enough thing to make. I think I may have had to grind some parts of the angle iron to clear various things, but nothing major.
Posted: Sat Jan 07, 2012 12:22 am
by cj91legss
I'm following what you're saying!
Posted: Sat Jan 07, 2012 5:19 pm
by euroshark
most knowledgeable subaru performance shops use oem head gaskets and will punch you in the face if you mention cometic.
btw, i see the discoloration in your pic. looks like a stain from burnt coolant=leaking head gasket.
Posted: Sat Jan 07, 2012 5:27 pm
by cj91legss
there's spots on the top of the rh side blockhalf that are pitted from being too hot. the leaking power steering that was under my intake manifold was boiling.
Posted: Sat Jan 07, 2012 5:54 pm
by euroshark
damn, thats terrible
Posted: Sat Jan 07, 2012 6:11 pm
by cj91legss
yeah, and with the rarity of the block, i may have to break down and buy an ej20....
Posted: Sat Jan 07, 2012 6:57 pm
by wurkenman
I learned my lesson years ago with Cometic gaskets and Harley's. I will never use their stuff. The best head gaskets are OEM.
