Need rear lower control arm (the back one of the three) by net week...
Let me know!
URGENT! Needed: rear lower control arm
Re: URGENT! Needed: rear lower control arm
Found a car for parts wagon l 90? will it fit a 92 wagon l? any idea?
looks like same part number, should be a fit hopefully.
you know...if you can, find one or ideally two with the sway bar bracket(s) on them if you currently don't have a rear sway (maybe you do) and make a nice little handling upgrade down the road.
That is an excellent idea, my ride suffers a lot from not having a sway bar
Not sure which one with a bracket will fit though....gonna do some research
