ej22e turbo?
colt45
ej22e turbo?
Post by colt45 »
im still looking for a ej22t block, but getting impatient. what are you guys using as far as tuning? i won't have a turbo ecu, and i won't use a fmu (already burned a hole through a piston)
with after market pistons, and rods, and assumed proper tuning; what are the limitations of the ej22e sleeves gonna be?
Mister Anderson
Re: ej22e turbo?
Post by Mister Anderson »
What part of the U.S are you in? It might be cheaper just to buy a SS. They are everywhere in Washington for fairly cheap. I bought a Haltech E8 plug and play standalone for my legacy.
colt45
Re: ej22e turbo?
Post by colt45 »
im in hoquiam, i'd go anywhere i could get a ss for releatively cheap though.
Mister Anderson
Re: ej22e turbo?
Re: ej22e turbo?
What compression ratio would you run with the aftermarket pistons? If you lower the CR, you can run similar boost as the turbo motor.
