Starter Issues, Need Help!!
courtjesterclown
Post by courtjesterclown »
Ok, here we go. So this past weekend we had a cold front move in, and about 8 inches of snow, got pretty cold. I went to start the car saturday night, and i heard a single click from under the hood, but the started would not engage. So i tried turning the key a few more times, and just still a single click with every turn. So i popped the hood, wiggled around the battery cables, and tried the switch again. This time, the starter engaged and turned over very very slowly then the car started. So i let the car warm up for five mins or so, then drove to the grocery store. As soon as i pulled in the parking lot, shut it off, then attempted to start it back up. Turned the key and the starter engaged and cranked fast like it always did and the car started fine. Got everything i needed,got back in the car, turned the key and it cranked slowly again but started. Got home, and havent been able to get it started since. The starter will not engage whatsoever, only the single click with each turn of the key. Today i looked at the cables and they did have the white corrosion between the clamp and battery post, also noticed the bare wire that connects to the clamps had a dull green color. I also tried to run a jumper wire from the positive battery post to the terminal on top of the starter, ( the terminal that is covered up by the plastic boot). Does anyone have any suggestions or ideas of what they think the problem is? Before i drop the starter and get it tested, i want to rule everything else out. The battery in the car is less than a year old. I tried to be as detailed as possible, any questions please ask. Thanks in advance.
1994 SS 4EAT Aegean Blue Metallic
BSOD2600
Re: Starter Issues, Need Help!!
Post by BSOD2600 »
Next time the starter just makes a click, try whacking it a few times with something heavy. this'll change the contact points touching the motor. This trick will work for a few more months until you get fed up with having to perform it ;)
Otherwise, sounds like possibly the battery cables are a wee bit corroded and could be replaced.
'11 WRX Limited
'94 TW | R.I.P.
I'd start by making sure the battery is charged and good. Also clean the corrosion from the cables. If you still have issues, it's the starter solenoid contacts.
http://bbs.legacycentral.org/viewtopic.php?f=19&t=41495
