i have a 92 legacy turbo auto, 3rd and 4th are slipping.
i would like to swap to a 5 speed out of a 1997 Outback or a forester. is this possible?
i have the whole car to take anything needed. would there be any electrical issues with it being a manual trans, like the TCU issues you run into with the auto swaps?
thanks for the help.
5 speed swap quick questions
Re: 5 speed swap quick questions
You can use that tranny. You'll also need the rear diff and a bunch of other parts. The electrical part of the swap is very straight forward. Check out Josh's write-up in the sticky compilation thread. There's no better resource for it.
http://www.surrealmirage.com/subaru/swap/swap.html
99 Outback Limited 30th Anniv. White/Sandstone
Riding on WRX Suspension and 17" Neon SRT4 rims
