Injector question.
Injector question.
Will any n/a red top work in my '93? I need to replace injector 1. Also, does it matter if I was to use an injector other than 1 from another car?
Danny
Re: Injector question.
Yeah, any red top injector from an Impreza or Legacy up through 1998 or 1999 will work. All four injectors are the same, so you can pull it from any cylinder.
If you're going hunting in a junkyard, you might just want to pull the entire passenger-side fuel rail from a 92-94 non-turbo Legacy; that'd probably be the easiest thing to swap. If memory serves me, those are the only models with fuel rails that'll bolt to your intake manifold.
