electrical problem help
Posted: Thu Feb 02, 2012 10:19 pm
by Naked Buell
I put the key in and go to turn to crank and nothing. Things just flicker. Swapped ign sw and does the same thing. Any ideas? I was thinking the battery.
Re: electrical problem help
Posted: Thu Feb 02, 2012 10:26 pm
by PhyrraM
Sounds like corrosion. Need to check both ends of the positive and negative cables. If those are good, then a bad battery or a battery that isn't charging (alternator).
Posted: Fri Feb 03, 2012 3:10 am
Yeah, check to make sure the battery is good.
Posted: Fri Feb 03, 2012 5:41 am
And check the battery terminals -- make sure they're making good contact with the terminals and are clamping nice and tight.
