electrical problem help
Naked Buell
Post by Naked Buell »
I put the key in and go to turn to crank and nothing. Things just flicker. Swapped ign sw and does the same thing. Any ideas? I was thinking the battery.
86 Brat, 2.2T, AWD, TD04, Intercooled,
88 Rx, Future EJ upgrade soon
PhyrraM
Re: electrical problem help
Post by PhyrraM »
Sounds like corrosion. Need to check both ends of the positive and negative cables. If those are good, then a bad battery or a battery that isn't charging (alternator).
Yeah, check to make sure the battery is good.
And check the battery terminals -- make sure they're making good contact with the terminals and are clamping nice and tight.
