weird check engine light
				slipknot51
I have a 1991 subaru legacy ss and i have been dealing with the check engine light for ever and the codes i have been getting have been changing and changing for some reason. I check codes this time and i have flash codes 21,22,and 49 i have recently replaced the knock sensor with a new one and i noticed that i went from the default 5.5 psi to 8 now which is nice. i dont have any running issues or performance issues the car runs and drives like a champ i haven't done any diag on the coolant sensor but i did for the maf and wiring looks good and sensor ohms out correct but i know that the coolant temp sensor is working right two because the gauge never reads anything funny just wondering on other peoples thought and what i should try to do
							92 T- leg Tdo4/top mount,3" inch exhaust ,5 speed 2.5 rs trans, sti seats Wrx rear seats  kartboy short throw shifter,Kyb gr2 struts
08 Spec b Legacy
						08 Spec b Legacy
Re: weird check engine light
Have you erased the codes or run in D check mode yet?
http://legacycentral.org/library/literature/codes.htm
04 Impreza WRX Sedan - Sold
06 Impreza 2.5i Wagon - Sold
92 Legacy SS Sedan - Sold
94 Legacy L Wagon
02 Rendezvous CXL
91 Legacy L Sedan FWD
94 Legacy L Wagon
02 Rendezvous CXL
Yeah I would suggest running the d-check mode to try and determine if there are any "active" codes stored.  Try that and let us know what you find out.
				slipknot51
Sweet I'll have to try that the next time i get the chance that is some nice information that you posted on here.
08 Spec b Legacy
						08 Spec b Legacy
