Tranny swap Questions
Naked Buell
Post by Naked Buell »
So I have a newer jdm 4-11 5 speed and its going into an older case to be able to use the cable clutch. But I think I prefer 3.9 gears so I am not doing 3500 rpm at 70mph.
My question is, can I just change the ring in the tranny as I am swapping guts??? Do I need the pinion gear that goes with the 3.9???
Please advise.
Thx guys
86 Brat, 2.2T, AWD, TD04, Intercooled,
88 Rx, Future EJ upgrade soon
Re: Tranny swap Questions
I would recommend swapping both the ring & pinion since they will have worn together evenly. If you swap a different pinion and ring set that have worn differently, that may cause issues. I can't say for sure, but maybe someone else will chime in.
You'll also need to set shims and proper backlash when changing gears in a different case.
