rod knock, 22 block or 25d motor?
bmxkelowna
Post by bmxkelowna »
so my black 93 daily has rod knock after a night of cyclones
at the local wrecker here there is a ej22t and also a ej25d from a legacy gt
now my question is should i buy the 22t block for 135 or buy the 25d block and heads for 165?
i know the comp ratio is a lot higher so id keep the stock turbo and keep the boost low
has any one else run the 25d motor on 22t ecu?
Mister Anderson
Re: rod knock, 22 block or 25d motor?
Post by Mister Anderson »
I would just put a EJ22T back in.
PhyrraM
Post by PhyrraM »
Yep, EJ22t. The 25D doesn't have a good reputation when turboed.
bmxkelowna
fiiiiiiiiiiiiiiiiine i pulled the 22 block today lol. 180$ later time to pull my motor now i guess
bmxkelowna
best part about the 22 block i got is it has 126km on it, thats only 78 292 miles
DLC
Post by DLC »
Indeed, given the option I would use that engine in any car. I have an EJ25D in my Outback and, while it's quite a good engine so far, I don't trust it like I did my 22T.
Legacy Central
