Hello,
I am not sure what the issue is, so I am just guessing on which forum to throw this in.
Mods can move as seen fit.
The car is a 93 Legacy L 5 speed w/ 218k miles.
I was curious if anyone had any ideas or could offer input as to what might be causing this sound.
It only occurs after I have driven the car for a short while and I can hear it only from inside the cabin, not the engine bay.
At first I thought it was like a clicking sound, but now I think its almost like that of a pump or of a small horse galloping slowly.
It's there every time right when I am about to turn off the car and have all other sounds turned off (fans, radio, etc).
The car has zero symptoms outside of the sound.
Could it be the brake booster or fuel pump going bad or something else?
I haven't had a chance to take it in to get looked at yet, so I wanted to get some input on potential ideas.
As always, thanks in adavance. =)
Mystery Sound Coming From Behind Steering Column
Brian
2001 Legacy GT - Sedan - White - Manual
18inch TSW Wheels, Federal SS-595 Tires, Centriic Rotors, Stoptech Brake Pads, STi Exhaust, & Torque Solutions Shifter bushings
dscoobydoo
Re: Mystery Sound Coming From Behind Steering Column
Not the fuel pump, as that sound would be behind you.
These cars do sometimes make a sound from the vent closure flap of the AC/heating control unit.
It can normally only be heard if it is in the off position and there are no other sounds.
Next time you hear it, turn the selector to defrost and see if it goes away.
Or turn the fan switch to 2
It does sound like a dull ticking that is rhythmic.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
dscoobydoo wrote:Not the fuel pump, as that sound would be behind you.
Yeah it definitely happens when the HVAC is turned off (I try to always turn it off right before I turn off the car).
I just tested it and when I turn the DEF on while the car is just sitting idle the sound goes away, but comes back again when I turn it off. When I turned the DEF onto fan 4 and then turned it off the sound only lasted a short while and went away.
Vent closure flap huh? Is it suppose to make that weird sound though?
Is it something I should replace or just know that its normal and deal with it?
Brian
dscoobydoo
We all just deal with it.
05 GD-STI
00- GF
05 GD-STI
00- GF
You can make it go away by lightly pressing one of the other buttons on the HVACcontrol unit -- not enough to actually switch the mode, but enough the make the "OFF" button pop out. It's not a solution, but it is a workaround.
That's interesting.....I don't have any noises with the HVAC door panels....
oldscoobyturbo
me either and having owned 6 first gens some with over 200k miles
the speedo cable noise is the worst or maybe the door seals
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
BoostedSubie
My wagon has done the exact same thing for years now, but have just ignored it cuz i don't feel like tearing apart the dash to get to the blend door motor.
93 Black Legacy SS
93 Legacy
97 Outback- EJ25D/22e frankenmotor
97 Green Outback
97 Red Legacy GT
98 Silver Legacy GT- Pikes Peak build, built EJ22t/205, GT3076r
99 Black Legacy GT wagon
93 Legacy
97 Green Outback
97 Red Legacy GT
