delta 2.2t re grinds
i have a set of never installed delta re grinds for a 2.2t sohc i beleve they are 230 grinds id have dubble check the boxes pm me or text 8602086869 200.00
oldscoobyturbo
Re: delta 2.2t re grinds
I have a set of these they are great
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
Still got these for sale?
_ruffmill
_ruffmill
Thesubielover
So It's one cam for 200.00?
Subarus have two heads. Each SOHC has one in each head. DOHC have four total, two in each head.Thesubielover wrote:So It's one cam for 200.00?
This is a good price and worth it. I have these and love them.
4Zero1 Facebook JOIN!
Subaru Legacy International
4Zero1Motorsports
2010 Legacy GT
1998 Legacy L parted
1999 Legacy GT SOLD
1995 Legacy L wagon parted
1992 SS 5 spd SOLD
1997 GT R.I.P.
4Zero1Motorsports
2010 Legacy GT
1999 Legacy GT SOLD
1992 SS 5 spd SOLD
1997 GT R.I.P.
I guessing you meant DOHCs have 4?
Yes
4Zero1Motorsports
2010 Legacy GT
1999 Legacy GT SOLD
1992 SS 5 spd SOLD
1997 GT R.I.P.
4Zero1Motorsports
2010 Legacy GT
1999 Legacy GT SOLD
1992 SS 5 spd SOLD
1997 GT R.I.P.
Thesubielover
Any power gains noticed with them?
Mister Anderson
I have the 230's and its all mid to top end power. you lose some in the lows but if I am driving fast its always going to be in the high rpms. You do get a rough idle though.
I am interested. For the guys that are currently using this grind. Do you have to alter timing at all to get a proper run, or are these a drop on replacement?
- Findlay
http://www.toolsource.com
Mister Anderson
I just dropped them with out making any adjustments. I would say it is on the border line though.
oldscoobyturbo
I'm working on raising the idle to reduce the choppyness otherwise they work great mid-top end is better.
Thesubielover
How do you adjust our idle? Im guessing it give a more throaty sound.
Thesubielover
Where are you located?
Still for sale?
Thesubielover
What kind of a shop can I have these installed? Any performance shop, like PIA or r&h garage? I hace money, but no time!
Just bought em. Thanks Church!
- Findlay
Thesubielover, pretty much any engine shop should be able to complete the install. Just FYI I think Delta is actually located in WA.
- Findlay
Delta is located in Tacoma, WA. I'm pretty sure they grind Subaru cams for $85 each, so $170+tax will get you a set of cams reworked locally.
Thesubielover
Nice, thanks for the info. What do I benefit from griding them
Delta takes your stock cams and adds material to them then reshapes the lobes by grinding them into a more aggressive profile. It improves power quite a bit at the expense of a little low end torque and with a little rougher idle.
SOLD....
