Looking for a 93 SS TCU pin layout
LGT Kirby
Post by LGT Kirby »
Trying to do a POWER mode mod, maybe some of you have heard of it.
I want to verify my pins before I go jamming wires in there hoping something works.
If you have a link handy, please post it!
Thanks.
Re: Looking for a 93 SS TCU pin layout
These are out of the 90 FSM.
http://www.main.experiencetherave.com/s ... _page1.jpg
http://www.main.experiencetherave.com/s ... _page2.jpg
The only difference between the 90 and the 92+ TCU is the following for the 92:
Connector 46, pin 7 - Brake Switch
Connector 46, pin 5 - ABS Signal
LGT Kirby
Post by LGT Kirby »
Thank you!
You're welcome.
wtdash
Post by wtdash »
Hi,
If you haven't seen it, here's a post on the power mod override switch.
FWIW, I had a '91 SS TCU and the power mode didn't work. I swapped in a '93 SS TCU and it did.
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
