Gauge cluster needle removal
Those of you that have swapped the backing for the speedometer or tachometer, how did you go about removing the needles without breaking them?
Alphius
Re: Gauge cluster needle removal
Post by Alphius »
I've removed and re-positioned my speedometer needle twice.
I simply take two flathead screwdrivers and put them on opposite sides of the round black needle base then twist the screwdrivers equally to provide leverage to gently and evenly force the needle straight up off of the gauge. It's a pretty tight interference fit, I was positive I would break something the first time I did it.
bmxkelowna
Post by bmxkelowna »
the metal pins that the needles are pressed onto like to break very very easy
Thanks guys. I'll try giving that a shot on my test combination meter.
BSOD2600
Post by BSOD2600 »
Josh:
Yup, same steps I used when taking the needles off mine. thread link.
Alphius:
Did the speedo become more inaccurate again? At least in 2009 after fiddling with the needle position, it was within ~1-2mph at 40 mph according to a radar sign and GPS.
'11 WRX Limited
'94 TW | R.I.P.
Thanks BSOD, now I remember that thread and your pictures. If I can get an electronic speedo, the plan is to pop the needle off, swap the faces and drive it via my Link ECU. Hopefully!
Alphius
Post by Alphius »
BSOD2600 wrote:Alphius:
About a month after I bought it it was about 10mph off on the slow side. E.g. when driving at an indicated 50mph it was closer to 60mph. I removed the needle and repositioned so it was accurate. This put the needle at about the 0, as shown here:
http://i627.photobucket.com/albums/tt35 ... 4dc808.jpg
When I did the WRX steering wheel swap, I took the opportunity to fix it again since it had drifted off again and was now indicating too fast, e.g. 60mph indicated was about 55mph. I moved the needle down and it now resides here and is within 1-2mph at all speeds:
http://i627.photobucket.com/albums/tt35 ... 5d3579.jpg
It seems like the speedometer in this car is experiencing drift issues. I suspect this is from a weakening of the magnetic field from sitting with the speedo cable in one position for a long time before you got it, I experienced a similar problem on my Camaro which sat for about 7 years, and in that car it was 30-40mph off and I had to replace the speedometer to fix it.
oldscoobyturbo
Post by oldscoobyturbo »
I have 3 spare instrument clusters for this reason. I have not needed to adjust my wagons or sedan so far gps says they are very good
Silver 99 Legacy GT Wagon
White 90 BC5 RS Type RA
