need some auto transmission specs
the94subaru
Post by the94subaru »
Hi does anyone have what the specs and tolerances for friction plates and steels are for a turbo legacy automatic I have mine torn apart and want to know if there bad because they really don't look like it. I think my problem might be in the valve body but would like to replace these while I'm in here if there bad. I have a really good tear down and rebuild book which has been good so far but for some reason I can't find this information any help will be appreciated thank you.
Re: need some auto transmission specs
You may want to take a look at book 3 of the Liberty factory manual. That's all I have scanned which may have the info you want.
http://www.main.experiencetherave.com/s ... tion_3.zip
