Where's the differential dipstick on 1991 FWD automatic?
91Beater
Post by 91Beater »
According to Haynes, its supposed to be somewhere on the right side. I believe I found the drain plug for th differential, but I can't find the dip stick. I found one on the driver's side for ATF but can't find the one for differential.
Alphius
Re: Where's the differential dipstick on 1991 FWD automatic?
Post by Alphius »
Passenger side of the transmission, doesn't stick up as far as the ATF dipstick on the other side. Should have a metal loop to pull it out that likes to hide under the A/C lines.
91Beater
Post by 91Beater »
Alphius wrote:Passenger side of the transmission, doesn't stick up as far as the ATF dipstick on the other side. Should have a metal loop to pull it out that likes to hide under the A/C lines.
I looked all over with a flash light, then from under neath and still couldn't find it. Is it to the front of or behind the axle?
Alphius
Post by Alphius »
All I have to check on is an AWD, but it is level with and about 4 inches back from where the speedometer cable enters the transmission.
You can see the two dipstick tubes in this picture.
http://www.surrealmirage.com/subaru/ima ... P_3217.JPG
The differential dipstick is just behind where the speedometer cable goes.
