Outback strut lift
SWRT
Outback strut lift
Post by SWRT »
Is this the best option for a small lift?
I've heard to use the Outback struts and
rear trailing arms, but is this the struts
from a Legacy Outback or an Impreza
Outback Sport? I'm planning to do this
stuff on a 92-94 Legacy wagon by the
way.
DLC
Re: Outback strut lift
Post by DLC »
Good question.
My 97 Outback has been lowered, and I've got a full set of stock struts, but I have never definitively seen the difference between the suspensions.
Legacy Central
The main difference is probably the location of the lower spring perch on the strut. The strut may also have a longer strut body as well.
DLC
Post by DLC »
I will try to get you some measurements of these stock struts.
Legacy Central
SWRT
Post by SWRT »
DLC: Any chance you want to part with the stock struts
or are you keeping them around just in case you
decide to go back?
That would be awesome! I'm not sure if I want to go
with the Forester stuff or not since it's probably a bit
more expensive and they're about the same amount
of lift. They charge more for SUV struts around here.
Legacy777: As in the spring perch sits a bit higher
off of the hub? (more of an angle maybe?) Cause
I know my stock Legacy perch sits really close the
05 WRX rims I have on there.
This thread covers most of your questions. There are side-by-side comparisons on the last few posts.
DLC
Post by DLC »
Thanks beatersubi
I don't know if it would make sense to ship these from UT to FL. You can probably find a set much, much closer to you.
Legacy Central
SWRT
Post by SWRT »
beatersubi: Yep, that helps a lot. Thanks man :D
DLC: Yeah, I'll give that shot. I haven't seen
an Outback in the junk yard for over a year now
though. Stupid FL and their anti-Subaru outlook.
zeke
Post by zeke »
i lifted my 90 legacy with struts off a 98 forester S it gave me 4 inches at the rear diff im also running 215/60r16 i will try to get some pics of what it looks like soon if anyone needs help just pm me
91 ss Ej22t dohc td04 sti Slanty haltech elite 1500
SWRT
Post by SWRT »
Dang, that'd be cool. Did you end up using any of
the spacers or the trailing arms?
SWRT wrote:Legacy777: As in the spring perch sits a bit higher
What I was referring to is where the perch is welded to the strut body. If the perch is raised slightly on the strut body, that will raise the vehicle height.
SWRT
Post by SWRT »
Gotcha. That's what I'm looking for
