Small rattle
Small rattle
Ive noticed a small rattle noise coming from under the car when I drive with my window down. I dont think it is the exhaust because it is stock and doesnt shake when I try to move it. I only happens going over certain bumps. Never notice it on smooth road. Other then that its great. The allignment is perfect.
Re: Small rattle
Is it in front or back?
Charles
Re: Small rattle
Sounds like the front
Re: Small rattle
If you just had Aliment I would look at the sway bar end links. Mine didn't look to bad but I replaced them because I replaced every thing else and that fixed mine.
I was just rembering that I also one other time one of my front calipers had worn sliders and would rattle when I hit a pot hole.
Charles
Re: Small rattle
Sounds like a fairly easy fix, I'll take it in this week to have them sort it out and tell me what the issue is.
Re: Small rattle
any other input?
Re: Small rattle
So had the rattle checked out and all of the above options werent the issue. I guess the guy said since it really only happens when the window is rolled down to try and tighten the power window assembly. Any thoughts?
