ej22t with ej20g heads?
KristianM
Post by KristianM »
OK! Now i'm a bit confused. Some say that ej20g heads will fit the ej22t block with no modifications, and some say that the compression will be to low, like 7.4:1.
The car is a 93 legacy turbo, ej22t, manual transmission.
So my questions are:
-What needs to be done for a head swap?
-Headgasket from a 2.0 or 2.2?
-Will the ej22t intake fit the ej20g headers?
-What turbo is stock on the ej22t?
If the compression gets to low, i'll just measure the cc and have the heads machined. Got a friend that does that.
KristianM
Re: ej22t with ej20g heads?
Post by KristianM »
Maybe someone got a list of all the specs on the ej22t engine?
There is a thread that details the modifications and parts needed to perform this swap. Search 'DOHC swap details' or, better yet, check the stickies as it might be in there.
