SOLD-FS:Innovate LC-1 Wideband sensor & new Blue Gauge
wtdash
Post by wtdash »
SOLD
Please HIT THE EMAIL OPTION OR I WON'T SEE RESPONSES.
Asking: $135/OBO, shipped * (see below).
Innovate DB-Blue Gauge and LC-1 Wideband AFR Kit -similar to - P/N: 3795 - #3795 on Innovate site HERE.
- LC-1 is USED w/a newer Wideband 02 Sensor - <less than 2K miles. Wiring is all there but is not original - see pics. The tab that aids in separating the 02 sensor from the controller broke off but it still locks in place, does not affect operation.
- Blue Gauge is NEW - P/N: 3793, includes the mounting kit.
- Includes a USB to Serial connector - w/software - that I only used on Windows XP -Not tested on Win7 or Vista(ke).
- Includes an extra bung for 02 sensor.
The Innovate LogWorks software can be downloaded from their site - HERE.
I know this works w/EvoScan and may work w/other logging software.
Close-up PICs HERE.
*Shipping- USPS Priority. I'm NOT shipping any of the boxes these came in - unless they fit in the medium priority box - included in pics to show P/N. If you need both, let me know.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Re: FS: Innovate LC-1 Wideband sensor and new Blue Gauge
Have you successfully logged with your LC-1 on EvoScan? I have EvoScan and it won't connect to my wideband. It shows up in the drop menu but won't connect to it or show any readings. Pissed me off real good because I paid for it and it's useless without my wideband readings.
wtdash
Re: FS:Innovate LC-1 Wideband sensor & new Blue Gauge +extr
Post by wtdash »
Kimo,
Yep as stated above I ran the Evoscan w/my LC-1 and it logged both. Does the Lc-1 work fine in the LogWorks software?
If you see it in Evoscan then it's probably setup there correctly but not 'passing thru'. IIRC, you know your PC stuff, so probably not helpful, but the Evoscan intercepts the data from the LC-1 connection, so you don't want both programs running @ the same time. Make sure LogWorks is OFF when running Evoscan. It's been awhile since I used it but that's how it works from what I remember.
GL,
TD
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
I never installed logworks. I'll try it again.
wtdash
Post by wtdash »
move it up
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
