5 spd tranny swap parts?
BadBenjamin
Post by BadBenjamin »
hey guys. i have a 91 legacy with a ej22t auto. the tranny is shot and i wanted to convert it to 5 spd. ive been checking the forums and im hitting the junkyards this week. i just wanted a checklist of everything id need to get to do this project. a tranny with a 39 gear, clutch pedal assembly, shifter/linkage, anything else? any help is appreciated.
91 lss. 02 wrx wagon. 04 sti
rallyak
Re: 5 spd tranny swap parts?
Post by rallyak »
don't forget the rear diff. and I think driveline is different than auto also.
Charles
wtdash
Post by wtdash »
HI,
Finding a 3.9 5-speed will be tough.
EDIT: see below - The Impreza had 3.9, too, but I'd be hesitant to use that tranny behind a Turbo engine. If you can confirm it's strong enough, then maybe that's the easiest swap.
Do some searching on here as the 5-speed swap has been covered. Here's JC's write-up on his experience - LINK. It's what I followed.
I used a '98 Forester 5-speed and rear diff - 4.11 final drive ratio....it bolted right up, other than some drive-line issues due to length and the rear pinion flange bolt spacing changed sometime after '94.
Your '91 has the rare rear VLSD, you can likely sell it on here to recoup some costs.
GL,
TD
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
rallyak
Post by rallyak »
Sorry totally missed EJ22T 3.90 gear in already. Yes trans will be hard to find in that gear.
Charles
BadBenjamin
I thought most 93 to 95 impreza carried that?
They did. My 97 Impreza OBS has a 3.9 final drive ratio. The gearing is a little lower than the turbo legacy gearing, but the final drive is the same.
http://www.main.experiencetherave.com/s ... f_info.pdf
wtdash
Post by wtdash »
BadBenjamin wrote:I thought most 93 to 95 impreza carried that?
I'd be concerned about strength behind the Turbo. I don't think I'd trust it, but maybe there's not that much difference between them?
Td
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
All the 5spds are pretty much the same. The only real difference is going to be syncro design, and if anything the synchro design will get better with a newer trans.
