There's a 96 Outback in the junk yard and
I'd like to throw the sway bars on my 94
wagon, but I'm not sure if they'll fit. I've
heard the rear one will, but I'm really
not sure about the front. Anyone tried
this before?
There's also the roof rack on the Outback
that I'd like to throw onto the 90 wagon as
well. The Outback looks like it might have a
curve in the roof. Has anyone tried this before?
I like the OB rails cause they're a lot longer.
There's also a 95 Impreza Wagon that I
could take the racks from, but they're not
as long and I'm still not sure they'd fit.
Anyone have any idea if either of these
racks will work?
Junk car parts - will these fit?
Re: Junk car parts - will these fit?
they both fit. the outback bars are 20mm front and 18mm rear which is a nice upgrade.
The only thing to consider is if your wagon does not currently have a rear sway, then you might need the trailing arms as well.
lucas wrote:There were multiple Legacys with 300k+ miles. Jesus will return on a Turbo Lego.
not the trailing arms. rear lateral links and swaybar mounts. you can take the links off the outback but the swaybar mounts are different. 04-07 rear swaybar mounts are the best ones to get.
They only had the rear sway bar left out of all of
those parts unfortunately I need the stock lateral
links from an outback then? The swaybar mounts for
which vehicle? An 04 to 07 Legacy?
sorry 04-07 impreza.
