Hard Brake lines kits where to buy?
Posted: Mon Apr 23, 2012 1:58 am
by dafrompa
Wanting to know a good place to buy hard brake lines kits with everything inclued such as the fittings, line, ext. I see on JCWhitney they have some hard line kits but unsure about if the fittings are the right size for our cars becuase the kits say they are for american restroration.
Re: Hard Brake lines kits where to buy?
Posted: Mon Apr 23, 2012 5:43 pm
The only place you'll likely find anything specifically for our cars is through the Subaru dealer. You may be able to find some used lines on a car in a junkyard.
Do the lines on JCWhitney say they are application specific or just universal fit?
Posted: Mon Apr 23, 2012 10:03 pm
by dafrompa
Just universal. The line are 3/16 but the fittings are what I am sacred of because I am not sure if they will be metric or standard.
Posted: Tue Apr 24, 2012 6:02 pm
Subaru fittings are double flare, and I don't believe most universal stuff are.
Personally, I wouldn't risk/chance it.
Posted: Tue Apr 24, 2012 9:14 pm
by dafrompa
http://www.jcwhitney.com/zinc-plated-br ... 9y1993u0j1
from what i see you need to bend the tubing and flare it your self to.
Posted: Tue Apr 24, 2012 9:36 pm
Yeah....you'd need to buy the bending & flaring tools as well. I really think your best bet is to try and find some lines off a car in the junkyard, or possibly from someone on the bbs.
Posted: Tue Apr 24, 2012 11:01 pm
by dafrompa
My father in-law got the tools so I am not much worried about that just if if will fit your not.
Posted: Wed Apr 25, 2012 7:25 pm
You make them fit....that's the point of "universal fit".
I'd check the outer diameter of the stock lines to see if they're close to 3/16". As long as you bend the lines to fit your car, have the proper fittings and flare tool to match the stock fittings, you should be ok.
Posted: Sun Jun 03, 2012 2:09 am
by xise
You can get the correct brake end fittings pobalby from JC whitney also, they do sell metric stuff there also. I have a few from when I did my nissan's brakes but I can't remember what size they are...pretty sure almost all jap cars are the same brake fittings. I want to say m10x1.5 but I will have to look into that...I am sure you can find that info somewhere, or just measure the threads and the hex from an old brake line.
Posted: Sun Jun 03, 2012 4:24 am
by BoostedSubie
I did all my brake lines on my car as I did the RHD conversion and the MC is on the opposite side and I deleted the ABS. I borrowed a flare tool kit from my buddy and bought the straight line by the foot as needed. It was pretty easy but then again my car was basically a bare shell at the time.
