Is the differential fluid separate from the tranny fluid?
SaltyBeefCubes
Post by SaltyBeefCubes »
In my 90 legacy fwd the tranny is making a gear wind noise. I noticed there is a differential dip stick and I never put fluid in it. I just filled the entire transmission up with oil assuming it was included. So my question is: does the differential need to be filled up as well via the dip stick tube?
SaltyBeefCubes
Re: Is the differential fluid separate from the tranny fluid
Mother of god...they are separate. Hopefully it hasn't been completely wrecked by my idiocy. Will normal tranny fluid work?
SaltyBeefCubes
Also, just kidding as well. It's 80w oil. Please disregard noob post.
Dave_J
Post by Dave_J »
Well, now your post count is at 40. :-D
You can use any good 75W90 in both Dif's and the Transfer case. Just don't put it on your Mashed Potatoes, tastes bad.
Retired US ARMY SIGNAL CORP
65 B-Cuda Formula S, 78 Dodge Little Red Express Truck, 08 Suzuki Burgman 650 Super Scooter, 94 Legacy Touring wagon.
For some reason the AT differentials call for 80w90. 75w90 should work as well.
