Do I still need my Boost Solenoid?
Posted: Thu May 03, 2012 1:43 am
by kimokalihi
I have a manual boost controller and my boost solenoid is all capped off. Can I remove it all together without causing any problems?
Also, For the other two sensors that I'm still using, do they need to be oriented the way they were from the factory? I just moved them behind the brake proportioning valve or whatever that thing is and they're crooked now. One is sideways and the other is upside down.
Re: Do I still need my Boost Solenoid?
Posted: Thu May 03, 2012 3:59 pm
by wtdash
You'll get a CEL w/out it plugged in - stock and EJ20G ECU. If you get a 'dropping resistor' (DR) from an AT-equipped car (turbo and NA) it will prevent the CEL- it has the same plug/connector. They are mounted on the backside of that bracket that holds the turbo sensors.
EDIT: Check the plug on the BCS. The DR were round on the '90-91 Automatics; square on the '92+. Per Josh's link below.
I don't know whether the other sensors need to be kept upright.
Td
Posted: Thu May 03, 2012 8:02 pm
by kimokalihi
So far no problems with the way they're mounted. What is a dropping resister? I'll go look for one in the junkyard. But I didn't think NA cars had that bracket?
Posted: Thu May 03, 2012 8:09 pm
by wtdash
Kimo,
Sir Josh created
THIS.
And a pic from an NA for reference. On a different bracket:
Td
Posted: Thu May 03, 2012 8:45 pm
by kimokalihi
I see, cool. Not as cool as removing it completely and not replacing it but that might be smaller and easier to tuck away where the other sensors got moved to.
Posted: Thu May 03, 2012 8:46 pm
by kimokalihi
What is this green labeled box bolted to the frame rail?
Posted: Thu May 03, 2012 8:53 pm
by wtdash
Huh...IHNFI.
Posted: Thu May 03, 2012 9:01 pm
by kimokalihi
It says "do not drop" on it I think.
Posted: Thu May 03, 2012 9:28 pm
It may be an airbag sensor or possibly a g sensor for the ABS system. I'm going to guess g sensor, usually the airbag sensors are closer to the front of the car.
Posted: Thu May 03, 2012 9:41 pm
by wtdash
^If his is a '91 - no airbag, so ABS makes more sense.
Td
Posted: Thu May 03, 2012 10:06 pm
by kimokalihi
Yes, no airbags for me. Except in my WRX seats...
Posted: Fri May 04, 2012 1:27 am
by kimokalihi
Picked up the na automatic resister for $3 at the junkyard.
Posted: Fri May 04, 2012 6:05 pm
sweet
Posted: Fri May 04, 2012 6:08 pm
by SiCkSTi04
kimokalihi wrote:It says "do not drop" on it I think.
Got a part number on that thing? I'm wanting to know as well
Posted: Fri May 04, 2012 6:54 pm
by kimokalihi
It's an ABS sensor. Probably to tell the computer which direction the car is going?
Part number 26740AA040.
SB117405 SENSOR AY [New Part# 26740AA040]
List Price:$222.37 (dealership)
Your Price:$160.10 (1stsubaruparts.com)
Posted: Fri May 04, 2012 6:55 pm
by kimokalihi
2nd google hit came up with this:
http://www.surrealmirage.com/vrg3/partnumbers/
ABS G Sensor
Posted: Tue May 29, 2012 7:56 pm
by i_c_the_light
I have been trying to figure out what that sensor is for the past 3 months!
Posted: Sat Jun 02, 2012 5:31 am
by cj91legss
hmm, maybe it should go away if you don't have abs
Posted: Sat Jun 02, 2012 6:41 am
by kimokalihi
It will when I get rid of abs. For now the ss sits collecting rust on its rotors looking real sad.
Posted: Sat Jun 02, 2012 7:07 am
by cj91legss
that is sad, I wanna get rid of my ABS too...
What do you need to do to get your car running again, just have that piece welded back on?
Posted: Sat Jun 02, 2012 5:24 pm
by kimokalihi
Don't know. Haven't even looked at it. I just removed the battery to use in my metro and went from getting 23 mpg to 42 and I haven't had time to pull the tranny to find out what broke. My guess is new clutch fork and clutch.
Posted: Sat Jun 02, 2012 5:36 pm
by cj91legss
no bueno
