intake wire harness
skygaze666
intake wire harness
Post by skygaze666 »
is there a difference between a NA intake wire harness from a turbo intake wire harness???looking o swap my crack and cut old harness for a clean one, and i am wondering if i can use a non turbo under intake harness in a a turbo ss and my car is a 92 legacy and na harness is from a 92 also..
Re: intake wire harness
Yes there is a difference. The non-turbo harness has the coolant temp sensors on the passenger side, while the turbo has them on the driver's side. Also, the plugs that connect behind the battery are different. That's really the main issue. You can always move the wires for the coolant temp sensors to the driver's side, however the connector plug is more a problem. You can try depinning and repinning, but that may be a real pain.
