Need some help with fitting my version 3 TMIC
I swapped a Ver3 RA/STi engine and trans into my legacy. Need to make the Y-pipe longer. What should I use or build it out of? Looking for an easy durable solution. Any help is appreciated.
Re: Need some help with fitting my version 3 TMIC
Checked the sticky in this forum for ideas?
build forum also has lots of ideas from members cars.
'11 WRX Limited
'94 TW | R.I.P.
Ya, I wanna build something that will reach the turbo. didnt really get any ideas unless I overlooked a thread. But this is what im dealing with. the bottom pic is a test fit
I have the same issue with my 02 wrx ic, I'm going to get a slicone e-bay y pipe and extend it by cutting it and adding a small section of pipe.
93 Turbo Wagon, 5mt swap, vlsd, sti slanty, vf10, alk, subframe lockout, gr2's, sti sways.
96 F-350 CCLB Powerstroke
89 Volvo 244, lsx swap
