BOV question
Thesubielover
BOV question
Post by Thesubielover »
Wondering if I am able to install my blitz bov on my stock ej22t engine with 3in tbe? Also, where would it need to be installed and what lines get connected to it? Thanks for all the help!
Robert
Re: BOV question
You would need to put it in the place of the stock bypass valve. Personally, I would not recommend using a BOV that will be open at idle. It's going to make the car run rich because it's letting unmetered air out of the intake.
Thesubielover
Re: BOV question
I've been trying to find this turbo vacume line diagram that I think you posted on here. Its was either a vf11 and td04 or one of the two, and it had in drawing the engine bay and everything that was in it related to vaccume lines I think. I printed it at work then forgot it! It seems as though it would be a great help to those wanting to install the mbc.
Thesubielover
Re: BOV question
Never mind, just found it. It was posted by vrg3.
http://bbs.legacycentral.org/viewtopic. ... ne+diagram
