Picture of horn relay?
slaytalera
Hey guys, I was wondering if anyone might be able to take a picture of their horn relay, I cant find mine at all. Its either been moved(had a remote start installed and they made a hell of a cabling mess under the dash) or it just isnt there period. Yes I checked the diagram, so i dont need anyone to post a scan of it, I just need to know what im looking for
FundamentalyConfused
Re: Picture of horn relay?
It's bright red colored about 2 inches long and square.
I found mine on the back side of the fuse box under the dash. There's a slot that it slides into that secures it directly to the back side of the box. If you take off your kick panel under the steering wheel you can almost see it with a flash light thru the hole where the tray is on the kick panel.
1999 Forester S 5MT 200,000 miles and counting.
1990 Legacy L Sedan AWD 5MT Retired at 369,471 Miles
