TD04 turbo inlet pipe.
Thesubielover
Post by Thesubielover »
I need some ideas. I am ready to do my swap, but cant decide which way to go. Am I able to just use a samco 90 with t clamps?
Thanks a lot, open to all ideas.
Robert
LegyC-LegyDO
Re: TD04 turbo inlet up pipe.
Post by LegyC-LegyDO »
yes, try to order a reinforced tight radius 90.
rallyOre.
91 legacy turbo
Thesubielover
Which one of these 90's should I order?
http://www.samcosport.com/usa/rp_standa ... #standard2
Thesubielover
Re: TD04 turbo inlet pipe.
The metal one wouldn't work, but that second one might work.
martimus919
Post by martimus919 »
This is my TD04 setup, the aluminum piping is Spectre Performance with a 90 degree reducer silicone to the turbo.
http://bbs.legacycentral.org/viewtopic.php?f=1&t=49555
07 Outback XT VF52
94 Legacy Sport, VF23, 550 RobTune, various other things
93 Legacy Touring Wagon EJ205 management and dash swap (in progress)
90 Loyale Turbo, EJ Turbo Swap, 2" lift
82 Brat, EJ22 swap, RX AWD trans w/ LSD rear, 5 lug 4 wheel disc.
Thesubielover
What are the measurments of the metal piece? 3in to 2 1/4?
martimus919
Both tubes are 3" in diameter and the straight is 4" in length and the 90 is just the mandrel bent one not the welded one you had shown. But I believe that the Silicone reducer is 3-2.25" and the black silicone is a flex hose that allows i think 20 degrees of movement.
07 Outback XT VF52
Thesubielover
What did you do with your f pipe and the other plastic pipe with one whole out to two? I just extended to crank case one, so its about 6 in tall vs 1in haha. I like the idea of having that black silicone piece. Where did you get the mandrel bend from? i have a resenator delete in the making, so ill pass on the 4in straight pipe, but id like to hear more about the rest of your set up.
Thesubielover
do you have a bulid thread? Also, is your bov hooked up to where the stock bpv used to be under the old plastic intake pipe?
martimus919
Under my pic is a link to my write up if you will, but here it is again.
07 Outback XT VF52
Thesubielover
Is the td04 2 1/4 od? There for id need to buy a silicone 2 1/2 id correct?
