I want to buy the electrical plug from the auto transmission. Since this will essentially ruin the transmission for future use, I'm hoping someone has a busted one they can cut about 12" of wire from the plug.
There are two big electrical plugs coming out of the AT, one is the E18 plug, and one is the E19 plug. I would like the E19 plug, which is a 16 pin plug, vs. the E18's 12 pin plug.
Here are the diagrams which show the two plugs. Both plugs are at the bottom right corner. The E19 plug matches up with the chassis B16 connector and the E18 plug matches up with the chassis B15 connector.
http://www.surrealmirage.com/subaru/fil ... ntrol1.jpg
http://www.surrealmirage.com/subaru/fil ... ntrol2.jpg
WTB Electrical Connector Plug From AT
Re: WTB Electrical Connector Plug From AT
Bump.
Here's some more info on what I'm looking for.
This is one of the plugs I cut off my old FWD 4EAT that has long since gone to the scrap pile. The 4EAT plug is on the left.
That's what I want, but I just want the other plug that has 16 pins.
Here's a pic of the trans and the connectors.
These plugs should be the same on the AT's up until about 1996 or so.
u in a rush for this?
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
BoostedSubie
I can get you one tomorrow from work. Plenty of old trannys just laying around.
93 Black Legacy SS
93 Legacy
97 Outback- EJ25D/22e frankenmotor
97 Green Outback
97 Red Legacy GT
98 Silver Legacy GT- Pikes Peak build, built EJ22t/205, GT3076r
99 Black Legacy GT wagon
93 Legacy
97 Green Outback
97 Red Legacy GT
Ok cool. Thanks!
