NEED ASAP: Injectors for '95 WRX
I'm not even 100% sure this is a '95 WRX engine. My guess is based solely on the trans ID number. I won an ebay auction for a '94 STi motor and this engine showed up a couple weeks later. Anyway, it has grey injectors and one is inop. I still need to swap the alledged dead one to a different cyl to verify it. Will '02 USDM WRX injectors work for me? This thing is running on a stock EJ22T ECU.
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
Re: NEED ASAP: Injectors for '95 WRX
Would these work for me?
http://www.ebay.com/itm/Nissan-200SX-24 ... 79&vxp=mtr
Labeled for Nissan, but they look the same as Subi ones.
Can't remember for sure, but I think someone is selling a set of grey 440s on rs25.com. That place and NASIOC have them fairly often. I wouldn't know about the Nissan injectors. I know there's an interchange between brands, but don't know off hand.
And oh yeah, even though they're 440cc none of the usdm wrx injectors will fit.
I have 3 440s in my glove box i would sell for 75 shipped, then you'd only have to track down 1 injector
Thanks for the reply. The car started running on all 4 again the day before I received a set of injectors from a guy on NASIOC. Now I don't trust it. Time to check out more of my crispy wiring.
Check the resistance on the injectors - should be 11-13 ohms, I believe.
Also, your original stock pink injectors will fit in the EJ20 Rails, since the 440's fit the EJ22T rails, if that's an option.
Td
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
