Turbo/more boost
keithmoilanen
Turbo/more boost
Post by keithmoilanen »
I have a top mount intercooler by Saab and a bigger turbo to throw in if I want, td04. how much boost can I run safely. Also it is a stalk engine and wrx tranny.
2018 WRX
1991 Legacy Turbo
Sold 1989 Lifted Wagon
Sold 1987 Wagon
Re: Turbo/more boost
If you up the boost beyond around 12-13 psi you will need a fuel cut defender. I think with that setup, 13-14 psi is probably ok, depending on the supporting mods. I would recommend a wide band O2 sensor as it is an invaluable tool to determine how much boost you can safely run and maintain proper AFR's.
keithmoilanen
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
keithmoilanen
Do u know of a good fuel cut defender I should look for
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
I don't know about FCD's, but have you looked into getting a bigger turbo? The stocker is pretty puny even maxed out.
keithmoilanen
I have a bigger turbo , have not put it in yet I think I got all the gaskets for it.. Any thing else I need to do if I swap it in?
Its the stock wrx td04 turbo
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Alphius
Post by Alphius »
The cold side output on the turbo points a different direction than the VF11 so you will have to re-engineer your intercooler piping.
keithmoilanen
Thanks pretty insightful, now if only some one close could help me out with my car.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
keithmoilanen
What bov is a good upgrade for the price
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Thesubielover
Post by Thesubielover »
Yo! I'm close, and just finished the same swap on my 93ss daily driver. We sould meet up sometime, either down there or up at my place. Some guys on the forum know me and have seem my place, so I have tools etc.
keithmoilanen
Yeah that would be sick
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
keithmoilanen
Thesubielover wrote:Yo! I'm close, and just finished the same swap on my 93ss daily driver. We sould meet up sometime, either down there or up at my place. Some guys on the forum know me and have seem my place, so I have tools etc.
this summer we for sure need to meet up.
2018 WRX
1991 Legacy Turbo
Sold 1987 Wagon
Turbone
Post by Turbone »
I have a TD04 on mine, with a Walbro 255lph fuel pump and WRX TMIC. Installed a AVO recirc on it recently.
Also have a fcd and I'm boosting at about 15lb. I have so much torque the stock clutch cant handle it.
But its not in a Legacy, its in my 89 RX.
I'm in the process of buying a house in Rochester, its about 20mi south of Olympia.
The place has a 24x36 shop out back :-D
89 RX w/2.2T
03 Fozzy
Thesubielover
I need some help installing my fcd.... I have a wideband ready to go in too
Turbone
Post by Turbone »
If you can wait a month I would be glad to help.
89 RX w/2.2T
03 Fozzy
Thesubielover
Turbone wrote:If you can wait a month I would be glad to help.
When are you local? I'll be moving to puyallup this coming month
